Applied force
Applied force
Is it possible to plot applied force in Abaqus. I can see that it's plottet in example problems, but can't figure out how to do this?
Senad
Senad
RE: Applied force
Then in the visualization module you can create an XY Data based on applied the concentrated force. You have to select the node where CF was applied.
Visualization Module->Tools Menu->XY Data->Create->
Source="Odb field output"
Position="Unique nodal"
Check "CF Point Loads".
Supply the node where the force was applied in the "Elements/Nodes" tab.
Best.
