How to calculate Boiler Stack Height for HR
Hello, i came across this topic and can't seem to find an answer. The boiler that is being used is a Horizontal Return Boiler with a Combustion Firebox in front of the boiler, the boiler HP is 100BHP. The solid fuel is regular pine. It is set at an open field with no restrictions. I am located at 1000m above sea level. I want to use natural draft from the stack height. Anyone know a good aproximation for the stack height.
Boiler has 3" diameter tubes.
20" diameter stack.
20" diameter stack.
RE: How to calculate Boiler Stack Height for HR
Have a look at these past threads, surely some would be of help:
thread403-128511: Exhaust stack sizing
thread403-175483: Rule of Thumb: Combustion air flowrate estimate?
thread391-206507: Boiler efficiencies
thread391-119121: Natural convection flow, chimney effect in a box
thread124-138283: Incinerator Stack Design Issues
thread124-145381: Correlation for stack friction factor?
thread127-97896: Tall Chimney lining
thread176-184873: Wind force coeff Cf when h/d > 25 for cylindrical structures?
thread378-111240: chimney calculation
