Metal Deck Attachment
We have a very small hanging load (~50lbs)that will be supported by a 22 gauge metal roof deck.  Does anybody have a bracket or hanger that would screw to the underside of the roof deck and can support a wire rope type hanging load.
RE: Metal Deck Attachment
Know any mechanical contractors?
They always seem to be hanging ductwork with toggle type bolts through roof deck.
I tell them they can't hang loads from the deck, but that only seems to make them stop long enough till I leave the job site.
There are a bunch of fasteners that may solve your problem..
Check with Simpson, USP, McMaster-Carr, Grainger, ITW or even Lowes.
BUT be careful not to penetrate your roof deck or you will have more problems --- like rain water leaks!!
Regardless of how small the load may be, I try to avoid relying on tensile capacity of a screw through sheet metal.  I would put a small bent clip angle that is screwed to the web of the roof deck so the screw acts partially in shear.
Unistrut. Really nice system. Might even work between 2 joists. :)
Threaded eyebolt with nuts and lockwashers top and bottom.  All materials hot-dipped galvanized.
Mike McCann
MMC Engineering
We've exhausted the uni-strut option...or, shall I say the architect has eliminated it.  We all know this is done all the time with electrical and mechanical contractors, I thought somebody may have a unique clip with some allowable capacities.  Thanks.
If it is to be specified on a new structure, how about a bluebanger with an eyebolt?  If it is existing, this won't work.
