Stiffness of Base Plate on Perimeter Wall
I am trying to figure out the stiffness of a base plate for a steel column resting on a perimeter foundations wall. I am running through the procedure in the PCI Design Hand Book (section 3.8.2). Using the PCI I can easily calculate the flexibility of the base plate and the anchor bolts but I’m not sure how to account for the flexibility of the foundation wall/footing.
The PCI does give an equation for the flexibility of the foundation but that is for an isolated footing only.
RE: Stiffness of Base Plate on Perimeter Wall
However, if you are talking about a short 6" thick stemwall, one foot or less high, over a thin strip footing, I would look to the spread footing comparison.
Anything in between, assume something between a spread footing and infinity. That close enough for you?
Mike McCann
MMC Engineering
