Welding Carpenter 20 to 316L Stainless Steel
Several Carpenter 20(Alloy 20)tubes are to be welded to a 316L stainless steel raised face pipe flange.
This is basically a P45 to a P8 weld.
Weld material for the 316L material is SFA-5.9 ER316L.
Weld material for Carpenter 20 is SFA 5.9 ER320LR.
What weld material should be used when welding Carpenter 20 to 316L stainless steel?
RE: Welding Carpenter 20 to 316L Stainless Steel
We used SFA 5.9 ER320LR for welding 316 to Carpenter 20 Cb-3 for use in a very corrosive process.
We've used ER320LR, ER309LMo, and ERNiCrMo-3 for these joints depending on Owner requirements.
