How to source the before motion from source file
Hi All
I want to source the custom procedure for before motion event.
I have sourced the TCL file, in which i have placed the new custom procedure for before motion, after placing procedure in before events, still it is not reading from the source tcl file
RE: How to source the before motion from source file
Are you trying to overload the MOM_before_motion procedure, or the PB_CMD_before_motion procedure?
In either case, I just tried this from a sourced file using the "Source Users's Tcl File" option on the Output Settings -> Other Options tab, and they both worked.
The sourced file must be in the ${cam_post_dir} folder, which is set by the UGII_CAM_POST_DIR environment variable.
If you're still having a problem, can you upload / attach the file you are sourcing?
Be Well
Tod (1d) Briggs
Manufacturing Solutions Architect
Siemens PLM Software
Detroit, MI
