looking for or how to .. sketch question
How can I get information if a sketch which sketch has lost a constraints( or isn't fully constraint) or dependencies from curves referenced to outside a sketch? Is there a check to analyse a part with many sketches not to to open and control each sketch
thx in ad
thx in ad
RE: looking for or how to .. sketch question
You can solve this problem by program in OpenApi.
Siwy
The ones I know of, outside the sketcher are information>object, and the by selecting any sketch in the part navigator interdependent features will be highlighted.
Best Regards
Hudson
-Dave Tolsma
Tolsnet LLC
http://groups.google.com/group/NX_CAX/
http://groups.google.com/group/plm-exchange/
I must learn /look how to use. At the first look I found a lot of check templates. I haved tested yet, but an other nice function would be to find broken / uncovered wave links. To cut it short. Can I check those entities in checkmate. A check template - I haven't found so far. Is this connected to the big wave licence?
Excused ask my ignorance. Thx in ad
-Dave Tolsma
Tolsnet LLC
Funnily enough there doesn't appear to be a great deal of sketch checking built into their tests.
One interesting effect of policing things become the unexpected responses that occasionally occur. I have followed your posts in this thread with some interest and wondered what you really wanted to do and why. If you intended to check that all sketches must be fully constrained then many people, might not be the sort of operators who would see it as a good thing. I remember well days gone by when a lot of people wouldn't use sketches at all because the system required that they be fully internally constrained which was at the time quite difficult to achieve. I wonder if all you might get if you policed sketches thus would be feature based models as a result of users abandoning the use of sketches. Sad but probably true.
Best regards
Hudson
