lead ballast
lead ballast
lead ballast
Why is lead used so commonly for ballast weights and not any other metal?
Thnks!
RE: lead ballast
'cause it's denser than most things
RE: lead ballast
lead is also relatively inexpensive, does not readily corrode but it is considered a heavy metal and can be the source of some medical problems and poses disposal issues.
industy is in the process of eliminating as much lead from electronics and plumbing (etc)
RE: lead ballast
Have you checked a periodic table of elements lately?
RE: lead ballast
Lead may not be not as dense as gold, platinum, plutonium or uranium.  But it is much cheaper.
- Steve
RE: lead ballast
I find it strange that this question comes from someone in the nuclear field.
RE: lead ballast
vscid, lead is relatively cheap, low corrosion, easy to form, relatively dense...
It does have the heavy metal/toxic issue though.
Then again look at a couple of the alternatives, Tungsten & Depleted Uranium also have their issues.
What other metal are you surprised isn't used instead?
KENAT, probably the least qualified checker you'll ever meet...
RE: lead ballast
Was just curious if you can divulge what you are talking about "ballast"(ing)?
RE: lead ballast
Simple iron castings are used most often as ballast weights as they are the cheapest and easiest to cast with no toxic effect. Remember lead sheets can be considered hazardous in some countries.
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
RE: lead ballast
arunmrao - cast iron/steel is common when volume isn't much of a concern but when density is a concern lead is (was) popular untill everyone got concerned about the potential health/environmental impact.
I've heard of ships using life expired inert aircraft bombs as ballast.  That's great untill someone checks the records and finds out that a couple of rounds with a 50lb 'spotting charge' may be missing!
I guess another downside of lead is its tendancy to creep under certain circumstances.
RE: lead ballast
Lead doesn't "creep" in England, it walks ... aided by thieves.
- Steve
RE: lead ballast
Pig iron at one time was commonly used for sailing ship's ballast, wooden ships and iron men and iron ballast.
The bay here did have a lot of pig iron on the bottom until WWII, when it mined. I did have a 90# bar of Swedish pig iron which was almost pure iron. This type iron was known for it's very low Phosphorous.
Arunmaro would love this iron for his foundry.
RE: lead ballast
I think lead is outdated for reasons given above, and actually used mostly for weighing firm mounted deep keels for smaller sailing yachts. Alternatve is steel or iron.
For commercial ships 'ballast' would be the weighing down for seafaring in stead of commercial load (commercial load not obtained)- eg.some cheap material without commercial value.
Ballast as for commercial bulk ships today will usually be water, causing problems with marine-life cross-spreading and polluting traces from load (oil, chemicals)
Earlier times sailing ships also used stone, or sometimes earth, with similar botanical problems.
RE: lead ballast
so long as you don't lick the ballast the health issues are minimal.  i think lead ballst is still used in planes, for both fixed ballast and removalable (lead shot in bags)
RE: lead ballast
Depleted Uranium is also reported to be used as counterweights in planes, encased in a steel jacket.
Lead, is easy to work with, cheap, corosion resistant,common and relativly harmless, well it was when i was younger, must be a more toxic version used now hehe.
www.retallickeng.com.au
Was told it couldnt be done, so
i went and did it!
RE: lead ballast
Tungsten gets used too on some A/C apparantly, I'd guess at significant cost impact.
