'DIHEDRAL' CHAMFER
'DIHEDRAL' CHAMFER
How can I creat a 'Dihedral' chamfer onto the end of a pipe?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: 'DIHEDRAL' CHAMFER
Dan
www.eltronresearch.com
chamfer at top is on the outside, chamfer at the bottom is on the inside... reverses on the centre line of the pipe.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Sweep w/ guide curves should work. Unfortunately, explaining is difficult (probably more difficult than the actual feature).
