Adding a New Frame to a odb file
I have two Odb files. File 1 contains the analysis of a model, let us suppose Model A and File 2 contains the analysis of the scaled Model of A.
What I want to do is have the original geometry from file 1 also displayed when I view file 2. So that I can compare for example the original geometry from file 1 with the deformed shape of the scaled model in file 2 ( see the displacements, have a screenshot together etc).
To put it precisely.
Step1.Frame[0] of file1 should be the new Step1.Frame[0] of the file 2. All other frames in file 1 should be incremented as Frame[i+1]
Anyone has a idea about how to proceed with scripting for the above problem
