Mouse Customisation
Mouse Customisation
I am currently using Autocad LT98 and have recently changed to a three-button mouse. How can I tell the Autocad software to recognise the middle mouse button, so that I may use it for screen scrolling operations? I.E. so that I can drag the mouse, holding down the middle mouse button, and thus drag the drawing up and down the screen.
RE: Mouse Customisation
Hope this helps.
MouseMan Wheel model with the latest drivers from Logitech. Microsoft
also provides drivers and support for the Intellimouse if this is the model you are using. In Autocad LT under "TOOLS" "PREFERENCES" the "SYSTEM" option should list the current system pointing device and should provide a description of the mouse type. The Logitech CD that came with my mouse did not have the latest drivers so that may be your problem.
Nicolae
