How to model column transfer
I have a situation where I have a concrete slab with a beam spanning between two columns and cantilevering from one side picking up a column.  How do I define the column that bears at the end of the cantilever is SAFE?  When I try to define a wall or column and try to delete the properties of the object below the slab, I get errors.  Do I have to apply a point load representing the column load?
