Resize Datums
Resize Datums
Where can I find resize datums or ref. xis in Nx5
in previous versions has had such a function...
what must I do in nx5.04??
thx in ad
thx in ad
RE: Resize Datums
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
RE: Resize Datums
but on reference axis I can not move the origin of the fixed axis its locked...
the resize command was easier...
RE: Resize Datums
In the case of a fixed Datums Axis you can edit both the length and origin, so in that case, nothing has changed.
As for referenced Datums, since by Definition they were created relative to some other object, while you can change their size, the location/origin remains fixed relative to the referenced object, however the size/length can be edited, which was NOT possible prior to NX 4.
As for the Datum CSYS, if you wish to change the relative screen size of it, just double click the CSYS object and in the 'Settings' section change the 'Scale Factor' to the desired 'size'.
John R. Baker, P.E.
NX Design
Cypress, CA
RE: Resize Datums
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
RE: Resize Datums
John R. Baker, P.E.
NX Design
Cypress, CA
