Please help, PCI !
Please help, PCI !
i'm a newbie in the PCI world , and i have a component which use PCI bus (ethernet lan controller intel 82559er). I must connect the IDSEL pin but i'm not sure where to put it ! (IDSEL --> AD17 ?)
Same question for the pin INTA# that i have on my component; note that is a one function component so i have just INT line.
My CPU core is a STPC Atlas (x86) and i have 4 line PCI_INT0,PCI_INT1 ...
I saw on the PCI revision that they can be a lot of way to do it !
Stephane
Stephane
RE: Please help, PCI !
There is a PDF file at this site you can download "FREE PCI Bus Quick Reference Guide!" . The info you need should be there.
