Milling CPM 10V
Milling CPM 10V
Has anyone had any luck milling CPM 10V? If so what did you use. We have used everything from Sandvik to Ingersol. Best luck was with Sandvik's new 490 2" Cutter 1030 grade. Tool life is not where I think it should be.
RE: Milling CPM 10V
We've been running CBN inserts with success on some Fe-W blend sintered PM parts that we make. The wear has been excellent. We'll use the CBN only for finish passes, choosing to rough with carbide and coolant instead. It may be a viable option for you. Here's an article for reference: http://www.mmsonline.com/articles/010203.html
