KFC 17
KFC 17
I have 2 KFC 17" monitors with the following problems:-
   1-  HOT was shrted, after replaced the monitor worked good, but the vertical image is too expanded and can't be adjusted by control buttons.
   2-  The diode near to the Flyback was shorted, after replaced, the monitor work but the image is wavy vertically.
 Please if you have any advice. Thank you
