Edit object display (again)
This is proving to be rather frustrating, I can't seem to get control of object colors and partial shading settings.
Example 1, I have a component with three dumb solids. Using edit object display on the solid bodies changes wireframe color but not shaded color... selecting the faces will allow me to change the color. I want to un-set all display properties of the faces and change the solid colors, is that possible?
Example 2, I have a component that I want to turn OFF partial shading in assembly. In the assembly I can override the component setting and turn it ON, or undo the override in component properties, but I cannot override to set partial shading off.
I keep looking for a switch to just clear/remove the color settings for an object (face, body, or component).
RE: Edit object display (again)
As for 2) and Partial shading, it behaves slightly differently. In that case, irrespective of whether you are working in the context of a piece part or an assembly, with your 'Type Filter' set to 'No Selection Filter' select ALL of display and over the highlighted model press MB3 and select 'Edit Display' and toggle OFF the Partial Shading option (make sure that it's toggled OFF as you may need to select it twice). And then hit OK.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
2, I'll have to try that in the morning. So far I have been using no selection filter and picking on components, I can unset the partial shading checkbox and hit apply (or set, apply, unset, apply... no difference) but it dosent take effect. I gather that your saying I must select ALL DISPLAY to get components, bodies, etc.
Hudson
Yes, that's the better solution when using Edit Object Display directly (I was using the 'workaround' that we used before we added that option).
John R. Baker, P.E.
NX Design
Cypress, CA
Yes good I saw your logic. Now if we could just make that tick a sticky setting in the future I'd be most appreciative.
best regards
Hudson
With NX 5, at least in your current session, once you toggle it ON, it will remain ON until you toggle it OFF.
John R. Baker, P.E.
NX Design
Cypress, CA
Yes I know, I think it would be better if either the default was ON, or I could otherwise get it to stay on most of the time. Several users I have dealt with requested help with this and I thought to mention it because it may salve their discontent.
Best Regards
Hudson
#2, In an assembly I have a sub-assembly. In this, one component has partial shading on, the other off. In the top assembly I can turn partial shading on for the whole sub-assembly. At this point MB3|properties shows a check next to Specific Partial Shading. If I edit display again, uncheck partial shading, it goes back to the default (one shaded, one not) with no check by the Specific Partial Shading option. I tried selecting a window around the offending subassembly and repeating the process, but still cannot get partial shading to turn off.
So I can force shading (specific partial shading on) but cannot force wireframe display. Is this just the way its intended to work?
I know I can go down to the component level to get results, but sometimes it would be preferable to do it in assembly.
I'd encourage you to set up a test example to try this out.
Start by turning partial shading mode ON, using a file where you haven't been playing with the settings. Everything should render as wireframe. Now if you force it to select a Solid body to edit object display and tick partial shading that body should be the only thing shaded. If the body lives within a component then provided that you selected the solid body or the faceted body and not the whole component then looking at the component properties under the assembly tab, there will be no tick alongside the item "Specific Partial Shading". Also under those circumstances if you change between the Model and Faceted reference sets the shading should switch on and off. If on the other hand you select a component to edit display and tick Partial Shading on, then the properties show a tick for "Specific Partial Shading", and it does not matter if you change reference sets the component stays shaded.
Having done that the same logic can be applied to the application of translucency but it is controlled separately from the partial shading. You'll find similar settings in all the same places. The only overlap is that if you're using partial shading, remembering that translucency applies only to shaded objects, anything set to be translucent but with partial shading off will appear as wireframe.
Apply to all faces can also affect your partial shading results with some really weird results if you turn it off and have the misfortune to select bodies rather than whole components. That is to say you could do the same thing by just applying partial shading to individual faces. You might try forcing select faces while editing object display to turn partial shading on and off in the same example.
Best Regards
Hudson
I see that display settings are not hierarcal. I can set faces and bodies in a screw component, then assemble that screw into another component. From this assembly I can then set either the screw component, or screw body properties, but they are only applicable to this particular assembly. If the assembly gets put into another higher level assembly, the display properties will be taken from the original lowest-level components. Furthermore, while I can un-set component properties so that display reverts to original, I cannot seem to un-set solid body properties that have been modified at the assembly level.
How's anyone supposed to figure this out? I have parts that change colors like a disco chameleon as I move through the assemblies, its disorienting.
The explanation is long because the what if's are many. The concept in practice is simple. The facility for users to apply these settings in a variety of ways does however produce variable results and you have to be aware of that which previous users may have let behind. Good housekeeping is ALWAYS best practice
Yes when selecting components there are few options basically it is just on or off.
You really do need to experiment with it to get a grasp of whether you consider it to be hierarchical or not. Lets just say that if you apply settings at all levels then it naturally makes things more complicated and it can be tricky to specifically turn off partial shading.
Reasons to be able to pick solids or faces with components might be that you just want to shade a single face or the component contains several solids. Using partial shading for one face at a time is a VERY handy way to be able to see where clashes between parts occur.
Best Regards
Hudson
The other translators use a null part and inherit their display settings from that file.
Best Regards
Hudson
best regards
Hudson"
I just stumbled across a setting in NX5.0.3.2 customer defaults, gateway, edit object display, apply to all faces. Is this what your after?
There are some settings that are controlled solely by customer defaults of which this appears to be one. And others where the saved behavior persists from session to session, hence "sticky". I discovered this as you probably did having not bothered to check until it came up in this forum. The difference between the sticky and customer defaults is often slight and in cases especially like this one pretty low priority. But I'd like to see more sticky settings used for dialog preferences, if only because these issues tend to disappear once they're implemented.
Best Regards
Hudson
I also wish that the "save dialog memory" switch for roles made some sort of sense, or had a help description that made some sense. I can never figure out what that does, and have to check my notes to remember if I want it on or off.
As for the 'save dialog memory' toggle, I toggle it off whenever I save/update my role (someone once told me to do that and so I do, but I can't recall what the issue was that prompted the developer to tell me to toggle it off).
John R. Baker, P.E.
NX Design
Cypress, CA
