Drag inoperative
Drag inoperative
Help, I can't drag some component parts when I insert them into assy's. Some do & some don't (more often don't). They move by mates but not free drag.
As a footnote I seem to have more trouble with 2008 than any other version
Cheers
Cheers
RE: Drag inoperative
I can't see why it should only affect some parts but check >Tools > Options > System Options > Assemblies and make sure that the "Move Componenets by Dragging" CheckBox is ticked.
If it isn't that, see if the part has a (f) before its name in the Tree Pane and if it has, RMB and select "Float" from the pop-up menu. Usually all bar the first part in an assembly is floating and is denoted by (-) before its name.
Finally check to see that no automatic mates have been created on insertion.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
Forgot to say that the (-) of a floated component, dissapears when it's position is fully defined by mates.
I've also tried dragging the part from the main assy into a sub assy in the manager tree & it can be moved as expected in that.
Probably because any mates created in the TL assy are being broken when the part is dragged into a sub-assy.
Is the sub-assy the part is being dragged into, set to flexible? If it is not, you should not be able to move the part.
Can you zip and upload the assy (or a simulation of it) for review?
"I've also tried dragging the part from the main assy into a sub assy in the manager tree & it can be moved as expected in that."
So, can the part be dragged around in the sub-assy? If it can, that means that the sub-assy is set to Flexible, and that some mates or constraints were broken when the part was moved from the main assy to the sub-assy.
