Unigraphics NX 4 Training Material
  Where can I find some inexpensive Unigraphics NX 4 training material, such as user manuals?  I know UG has CAST, but it does not appear that the company I work for has UG CAST on it.  Perhaps, it's something that needs to be activated.  If so, where would I go to do this?
Jason,
CTQ Engineering
Technical Team Leader
GE Product Definition Designer
RE: Unigraphics NX 4 Training Material
Jason,
For your training you probably should have at least one CAST  license if only for the worked examples, but try also www.myigetit.com if you like. For users of earlier NX upgrading to NX-4 I would simply read the what's new guides and entering the dialogs for the first time I would hit F1 for help and pick it up that way, because the changes aren't that dramatic that you should need to re-learn NX. In fact part of my training method is to turn on all the icons that I know that will be used then hit F1 for each in turn have the trainees read it once then I just fill in the context of how and where you would use each tool, and provide some working examples.
Best Regards
Hudson
