What is the maximum pressure for a banjo fitting.
I am installing a fuel injection system on my 65 mustang. I would like to hide any indication of the modern upgrades. To do this I wanted to use fuel banjos to feed the injectors. So, the question I have is can I use the banjos with crush washers to feed the injectors at the required pressure or is the pressure going to burst the washer.
RE: What is the maximum pressure for a banjo fitting.
www.retallickeng.com.au
Was told it couldnt be done, so
i went and did it!
On the brake systems of both my race cars I replaced the OEM banjo fittings with AN fittings. Not because of any failure related problems but for ease of maintenance with braided teflon/steel lines.
Rod
You can absolutely do this, but like evelrod stated, servicing AN fittings may be easier for future maintenance.
-Reidh
Rod
