Any Idear On what type of led this is?
WE are currently looking to replace a failed LED but its not like any i have seen before. its a 24v unit with a 1.2k resistor fitted into it.
i know i could just change out the whole assembly and replace with a new one but this is a real work up as it involves shutting down production to gain access to the 24v connections.
RE: Any Idear On what type of led this is?
Looking through the blur it seems to be a cluster type, and the resistor looks like 1.6k (brown-blue-red). What are you hoping we can tell you that you can't see yourself?
any idears as to where i could find one? tried usual searches but to no avail.
The connection ends are 1mm flat connectors.
was hoping someone had seen one like it before and had an idear as to where i could get them.
i think i may have to go down the route of waiting till a shutdown period and repalce this whole unit to a more standard one.
BK
