Analysis Method in ANSI/ALI ALCTV:2006
I am performing Design Analysis on an automotive lift. According to ANSI: "The allowable stresses (strength factors) defined in this standard are based on the assumption of analysis by classical strength of materials methods (models), although other analysis methods may be used". How do you use FEA results to comply wiht this requirement?
