ASME B31.3 Internal press. of pipe
ASME B31.3
Maybe I didn't read the code entirely,
but can someone explain what units to use in Part2 304.1.2
PD
Formula t= --------
2(SE+PY)
What units do I use for P,D?
PD
Formula t= --------
2(SE+PY)
RE: ASME B31.3 Internal press. of pipe
P in psi, D in Inches, S in psi will give t in inches.
or
P in N/mm^2 , D in mm, S in N/mm^2 will give t in mm.
