Cosmos Motion-Getting Graph
Hi..
I am trying to simulate a pneumatic arm mechanism which is pressing the materials.Materials are passing under this mechanism. I have a roller which will press the material and drive it to forward. This material thickness is changing between 50-300 unit. By each thickness the pressing force is going to change because of the changing arm angles.I have a constant pneumatic force and a constant velocity. How can i get the graph of reaction forces of the roller which are changing by the material thickness .
