Nois level inside Anechoic Chamber
Dear sirs:
If an anechoic chamber was for sound isolation, inside noise level should be below 20 decibels.
Is the same requirement mandatory or advisable for RF anechoic chambers?
What is the noise level usually recommended?
schola
schola
RE: Nois level inside Anechoic Chamber
Second, you can't say that the ambient sound level in any anechoic chamber must be below 20dB. The minimum level required depends on the minimum level you wish to measure and what you level of certainty you want/need. It may also be dependent on some industry spec. If you are trying to measure a jet engine at 140dB does it really matter if the background is 20 or 30dB?
So in regard to you question:
- Do you need to meet some industry spec?
- Depends on the minimum level you wish to measure and what level of certainty you want/need. (which also drives the measurement devices)
- budget (as always!)
ISZ
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
