Nonmagnetized neodymium
If I need to attract a neodymium magnet stronger and have the flux travel farther than I can get with mild steel can I use a piece of nonmagnetized neodymium? Will the nonmagnetized material become permanently magnetic if exposed to a strong field?
RE: Nonmagnetized neodymium
What are you trying to do?
If you're looking for a high permeability material like steel/iron, Neodymium is NOT it. It has very low permeaiblity. And as mentioned can retain high residual magnetism.
TTFN
Just an idea.
