project technologist
Hi, am new in the oil and gas industry employed as a project technologist. What is its  job description. i work in a refinery due for upgrade. please advise since there is also an engineering department dealing with projects. i am a  chemical and process engineer.
regards.
Dickens K. Seroney (B. Tech in Chem and process eng.)Moi,Kenya
Planning and development engineer.
RE: project technologist
Uh.  YOU took the job, why don't you know what the job description is?
Ask your Human Resources department for the job description.
don't bother with human resources, they are usually clueless.   Ask your supervisor for it.  However, he should have given it to you when you were hired.  Be careful here because, you will either be admitting that you weren't paying attention when he told you the first time or that he failed to tell you what it was when he hired you.  And what does the engineering department have to do with this?  you were hired as a technologist in another department.  you can't jump ship now.
I don't care much about job titles and formal job descriptions, any job is what you make of it.
I've seen two people in the same job ("maintenance technologist") in two similar units of the same company. One was practically running the unit, the other was little more than a clerk.
thanks guys for your advice at least i followed your instructions and i now got my job description.
Regads
