Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your information in this site is absolutely WONDERFUL. It is the most useful site on the web to me right now. Thank You Thank You..."
Geography
rchitorture (Specifier/Regulator)
4 Apr 08 5:00
HI,
I am currently working on an Architectural design proposal which may utilise Sand Liquefaction. I need to know about this in more depth and would appreciate the ins and outs of inducing liquefaction (and if its possible).
Can localised induced liquefaction assist in circulating the sand on a sandy beach (below surface level, so.. 'underground'), assisting its journey back into the ocean? what are the limitations? and is this even possible?
Thanks in advance and i hope to chat to some of you about this.
muuddfun (Geotechnical)
4 Apr 08 12:37
What is the pourpose of trying to induce liquefaction? What are you trying to achieve?
6 Apr 08 9:03
Thank you for your reply. I am working on a conceptual proposal, which looks at shifting/removing wind blown sand from areas in which it has accumulated. I wanted to propose an idea which utilises a vibrating plate, which could somehow be placed within the surface of the sand-bed (underneath the areas of anticipated sand accumulation). If it was possible, there might be a void beneath the plate, which will allow the sand from the top surface to 'sift' / fall into it. Off course, this will simply move the problem from the beach surface to the void below the surface. I then thought that perhaps i could utilise 'liquefaction' to induce the sand circulation sea wards, freeing up the proposed void allowing more accumulated sand to be cleared from the top beach surface.  scale wise, it's question of 100's of square metres rather than 1000's. I realise this may sound a bit far fetched with liquefaction being a fairly uncontrollable thing once it has been put into motion and i simply need to know if this idea is even worth building upon. The idea came to me after i had experienced small patches of 'quick sand' on beaches. I can send a sketch through to clarify my idea, should you have difficulty understanding it. Again, thanks for your reply!
6 Apr 08 19:39
From what you describe I would think it would be very difficult to achieve what you want at any reasonable cost with a modified vibrodensification strategy.  What you are describing could be called lateral spreading by induction of a vibrofloat.  You would need some lateral relief of elevation fist of all to be able to get some lateral movement of the sand. Second the vibro equipment is mostly used to densify the sand in place and so I don't see much lateral movement as occuring although it would be theoreticaly possible.  Thirdly it is not cheap.  Probably better to just use conventional earthmoving equipment.  Sorry to rain on your idea.
7 Apr 08 8:03
Thanks again for your reply, it was very useful! I've been trying to place a technical phrase on what i was visualising, so at least thats been solved! When you say 'lateral relief of elevation', do you mean a slope of the site and that it needs to be significant enough to cause the movement? in cross section, the site has an approximate slope downwards to the Adriatic sea of 7/100 (quite gentle).
BigHarvey (Geotechnical)
7 Apr 08 9:38
There is a project in Capbreton / Hossegor ( SW part of France ) where a similar project is underway. It is not wind but current that produces accumulation of sand on one side of a channel built between two dikes and erosion on the other side. A pumping station has been installed with a syphon and sand is pumped from time to time with a crane suspended dredging pump and sent from one side ( accumulation ) to the other (erosion ) to restore the sand beach.
7 Apr 08 13:12
Yeah you have the right picture, a 7% slope may be enough depending on the blow counts of the sand to get some lateral spreading, but again I would think it impractical, probobly better to dredge like BigHarvey is saying.
You might want to look up on the internet papers on lateral spreading by Les Youd.
9 Apr 08 14:00
Thanks all for the advice.I will have to look at the suggested examples and get back to you. Thanks :)
DRC1 (Civil/Environmental)
18 Apr 08 14:38
Treament plants use fluidized beds to liquifysand filtes for cleaning. This concept may work for what you are looking for.
18 Apr 08 15:01
Thank you for that advice. I will have a search. am still looking into this strategy.
Close Box
Join Eng-Tips® Today!
Join Us             Close
