Saving components in the same folder
I have an assembly, In which their components are assembled from different different folders. Is there any way to save/move the all the components into a same folder where top assembly file saved by single operation.
( Example: In catia V5, Using save management, propogate directory)
Thanks for your replies.
RE: Saving components in the same folder
http://www.w-eng.de/ugzipc.htm
Siwy
Rafi
You can also look into cloning Assemblies>Cloning>Create Clone Assembly. By intention the dialog forces you to change the output filenames slightly, for example by appending a prefix or suffix. It may be the case that you need to do this anyway or that it is just a good idea to help you better manage your data.
Why it doesn't also contain the ability to simply clone the assembly with no name change in another directory I don't know. It would probably be a good enhancement if it hasn't already been introduced. I should mention that I haven't verified what NX-5 does at the time of posting.
In the meantime many people have been using UGZIPC to get around this limitation, as SIWY suggests. Note however that it does require a UG Open executable license which most will have but some may not.
Best Regards
Hudson
Thanks for the help...
Cloning assembly is a good idea...
Rafi
A Datamanager role.
-Dave Tolsma
Tolsnet LLC
http://groups.google.com/group/NX_CAX/
http://groups.google.com/group/plm-exchange/
That's what UGZIPC does in fact.
On the downside I think neither works out of Teamcentre, but you'd just export the assembly to native then zip it anyway.
Best regards
Hudson
Good to know that UGZIPC does this, I would be more of a fan of this type of application if it was open source, but that is just me. Large companies that want to see it supported can pay maintenance.
-Dave Tolsma
Tolsnet LLC
I thought it is freeware, or shareware on a voluntary basis.
Hudson
