Potentiometers and silicone sealant
I am using a potentiometer in a an application and I have been told that using Silicone sealant near it could give off fumes that effect the resistance and give false readings.
I have looked at the data sheet and the fumes given off is Acetoxysilane (acetic acid).
Can anyone help regarding this.
Highest regards,
Russell........
Highest regards,
Russell........
RE: Potentiometers and silicone sealant
There will be problems if RTV is applied to a metal surface and closed in a housing or enclosure uncured. The acid will corrode or disolve any metal it has been applied to.
Cure time will vary with how much is applied to specific area. A dab about the size of a pencil eraser will take approx. 2-3 hrs @ +65 degrees C in a circulating chamber.
automatically etc.
<nbucska@pcperipherals.com>
http://www.trade-india.com/dyn/wt/gdh/eyp/view_adv.epl?list_id=70887
