Concrete Joist Floor Fireproof Cracking
I am currently working on an existing structure with concrete joist floors. The I-beams supporting the concrete slab are wrapped with wire mesh. The wire mesh is supporting about 3" of concrete, for fireproofing, below the I-beam. There is a crack that runs below the length of the steel beam (in the area of the fireproofing). I have calculated that the wire mesh has enough capacity to carry the concrete but the occupants of the building find the crack unsightly and would like to cover it. I was wondering if anyone has any ideas of how to seal the crack with some type of product that has an appropriate capacity in case the wire mesh was to fail. Also the product needs to be fire resistant. Please let me know if you have come across this same problem or have some type of solution. THANKS!!!!
RE: Concrete Joist Floor Fireproof Cracking
Good luck,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
