Reflective Foil - Hight Temp
Does anyone know if there is a thin foil on the market (similar to aluminum foil except obviously not made from aluminum) that is highly reflective that could help block heat transfer by radiation, but that can also withstand the heat of an aluminum casting process (1000+ degrees F)
I haven't had any good results yet from searching the web.
Thanks in advance.
Thanks in advance.
RE: Reflective Foil - Hight Temp
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
http://w
A word of caution:
This metal will cut you faster than razor blade.
When handling metal of this thickness make sure you have on cut protection gear, like cut resistant gloves and gauntlets.
