Assembly hide/show component - fade feature
OK.
Here's a question for you SW wizards. In an assembly, when I want to hide or show a component, the picked component fades respectively. Is there anyway to eliminate the fade feature and have the component just 'pop' in or out? This gets particulurly annoying with components with lots of detail that slow down the process.
As always all responses are greatly appreciated.
SW 2008 SP 3.0
WIN XP SP 2
Dell 380
nVidia FX1400
RE: Assembly hide/show component - fade feature
Go to Tools\Options\View, and you can adjust the speed things hide or show.
Dan
www.eltronresearch.com
Tools > Options > System Options > View.  You are looking for Hide/Show Component.  Slide the slider to off.
That worked!!!
Thanks to both of you!
