Steel beam design where brick wall is removed.
I am opening up an existing 8" brick exterior wall to 16'-6" for a room addition. I need to keep the ceilings flush and the depth of the floor joists above is 9.25", so I am limited to about 9" for the new steel beam depth. I am figuring the load on the beam to be to be 2220 pounds/foot. The question is if I use A-50 steel instead of A-36 steel does the "E" number, 29,000,000 change between the 2 different grades of steel? I am having problems with deflection--l/600 for masonry.
RE: Steel beam design where brick wall is removed.
Try designing your own beam made of plates maybe?
The masonry is existing right? Is your L/600 load include the brick? Where does the 2220#/ft come from?
RC
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
How about using an W8 with side plates? or a W8 with cover plates?
I'm thinking I can change the direction of the new flat roof rafters and I can omit their load from the beam design. If I do that I'll have a design value of I of 288 in4. Additionally, if I install a 4x12x1/2" steel tube on the existing exterior of this 8" brick wall and a 4x8x1/2" steel tube on the interior of this brick wall with a 1/4"x12" steel plate shop welded to the bottom of the 4x8x1/2" tube, I can then field weld the 1/4" plate to the 4x12x1/2" steel tube.
I am thinking that this would make the installation of the beam relatively easy. What do you think?
civilperson. He stated it was in place of an 8" wall. If you look at the W8 sections, you wouldn't be able to fit 2 beams into this area next to each other. What is the steel beam connecting too? Or is it just bearing in a pocket? You may be able to count on some stiffening from the connection and this may also reduce your deflection.
If you are a member of AISC you can search for papers about this topic.
RC
Edmund Burke
What if you installed a beam at a floor above to relieve some of the load on the lower floor?
Mike McCann
MMC Engineering
A cambered beam beam will deflect as much a a non cambered beam, just starting from a different point. Also a cambered beam will initially only support the brick wall at the mid point. I would not recommend it.
What keeps the water from running down the 8" brick exterior bearing wall and going into your new room? Also, it will be difficult for the contractor to shore the wall to install the beam. You might want to consider removing the entire brick wall and replacing with a stud bearing wall with brick veneer above the beam.
This not true. You do not need to include any load applied to the beam before the brick is installed including the beam weight but any weight including the weight of the brick should be used towards the l/600 calculation.
I've used a slick detail using two channels. Place on on either side of the brick above the opening, through bolt them together, and connect the bottom flanges with a steel plate (continuous or intermittent). That way you don't use up any soffit depth.
Of course, the channels will be exposed to view so you'll need architectural approval for that. You might also neeed to find a way to deal with water migrating in from outsite. I think it looks cool. I'm hardly impartial though...
I often use the double channel Adam suggested. If you cut a horizontal groove into the the brick you can turn the channel leg in towards the wall into the cut and have the channel directly support the wall without need for shoring.
Make sure you alert the architect to the water problem as it will be a problem.
The OP said the depth limit comes from ceiling depth, no width limit is required when the wall is removed below as long as there is support for the extra width at the ends. Two W8 beams with a common plate across the top is what I envisioned for a shallow support with twice the moment of inertia of one W8.
This is why after I stated it wouldn't fit if pocketed, etc. I questioned how it was to be connected. I would imagine the width would be somewhat constrained by the width of the wall if the beams are spanning due to existing framing in the structure, just my guess though.
Hopefully BRENDANF has resolved his issues.
What did you end up doing BRENDANF?
RC
Edmund Burke
We have "special" beams here... They are able to take a lot of "stress", so they do have feelings. Also, they do get tend to get torqued about a lot of the pressures they experience. Nebvertheless, it's shear ecstasy for them.
Mike McCann
MMC Engineering
I planning using a W8x48 with at 1/2" steel plate welded to the bottom of the beam.
Thanks for your help!
I plan to use double 8X6X1/2 angles with the 6 inch leg cut in the existing wall on either side and then through bolt the vertical legs on 2.5 foot centers.
Question - I see references to channels being used for this purpose but not many about angles. Is there experience out there using angles?? Thanks
have you thought of possibly, after the brick is removed from below, coming back and adding a plate across the seam of the angles so it will act as a single lintel.
Through bolting seems that it would damage the brick/block right above the lintel and that doesn't seem like a very good idea. Our typical details are for what I mentioned above. We've used it it many applications.
Hope that helps.
RC
Edmund Burke
