Link Part Name
Link Part Name
Link Part Name
I am sure this is an easy one, but I am stumped.  I am looking for a way to tie the part name to our title block.  Kind of like linking to attributes using <W@attribute>, but where attribute is I would like it to link to the Leaf name.  Any help would be appreciated.
We are using NX3, with no Teamcenter.
RE: Link Part Name
Ok, I did some searching and was able to make this work using journaling.
I tried running the .vb file with a macro, so I could incorporate it into a toolbar, and it doesn't work.  Is there a way to add the .vb to a toolbar button?
RE: Link Part Name
Using Customize, when you add a 'User Command' to a toolbar, under 'Edit Action', you can link to any of the following 'executables':
Journal Files (.vb)
User Function (.dll)
System Command
User Tools (.utd)
Macros (.macro)
GRIP (.gx)
KF Application (.dfa)
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
RE: Link Part Name
I got this figured out as well.  I just edited a toolbat to link to the .vb instead of the .macro.
RE: Link Part Name
thanks for your help, John.
RE: Link Part Name
On this same note,
I have also found a .vb script on this site to make each part of an assembly the work part, and then it writes info about that part to a text window.  See link below
http://eng-tips.com/viewthread.cfm?qid=187186
also quoted below.
Can anyone provide me with a line of code to add to this in order to add an attribute to each part that is the aprt name, and where I would add it?  I have come up with adding:
"part.SetAttribute("FILENAME",prototype.Leaf)" right below the "do stuff here" line in the code below, but that doesn't seem to exactly work.  I know this is wordy, but any help would be greatly appreciated once again!  Thanks
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Assemblies
Module NXJournal
Dim Session As Session = Session.GetSession()
Sub Walk(c As Component, level As Integer)
        Dim children As Component() = c.GetChildren()
        Dim child As Component
        Dim prototype As Part
        If TypeOf c.Prototype Is Part Then
            prototype = CType(c.Prototype, Part)
            session.ListingWindow.WriteLine(New String(" "C, level) & prototype.FullPath & "  " & prototype.Leaf & " " & c.Name)
             msgbox("do stuff here") ' add lines to write to a file or an array
               For Each child In children
                   Walk(child, level + 1)
            Next
        Else
            session.ListingWindow.WriteLine(New String(" "C, level) & c.Name & " is not loaded")
        End If
end sub
Sub Main
session.ListingWindow.Open
Dim part1 As Part
part1 = session.Parts.Work
  Dim c As ComponentAssembly = part1.ComponentAssembly
Walk(c.RootComponent, 0)
End Sub
End Module
RE: Link Part Name
Have you tried just adding,
"prototype.SetAttribute("FILENAME",prototype.Leaf)"
Below the do stuff section??
Mark Benson
Aerodynamic Model Designer
RE: Link Part Name
Thanks Mark,
That seemed to do it.
RE: Link Part Name
I would also like to add the username of the person creating the drawing to the attributes.  Does anyone know how this is referenced?
RE: Link Part Name
That will probably require some type of program.  I know that it can be done with GRIP, and I assume that most of the other programming options should also provide support for this.
John R. Baker, P.E.
NX Design
Cypress, CA
RE: Link Part Name
Do you know what the variable is though?  For instance session.parts.work.leaf is the leaf name.  Session.parts.work.(username) is what?
