numerical parameter including in string parameter
I'm trying to write nodes into files
NWRITE, Fname, Ext, --, KAPPND
with ascending file names using a loop, where Fname is ascending. Something like:
file1.txt
file2.txt
fiel3.txt
My problem is the conversion of the numerical parameter into a string parameter. This one doesn't work (this is only the part that should generate "Fname"):
*DIM,name,STRING
*DO,i,1,10
name=file'i'
*ENDDO
The following warning pops up:
"String parameter must have subscript."
From the Ansys manual, I'm referring to this paragraph (ANSYS Parametric Design Language Guide, 3.5):
"You can prevent parameter substitution by enclosing the parameter name with single quotes ('), for example, 'XYZ'. The literal string is then used; therefore, this feature is valid only in non-numerical fields."
Thank you for any hints here.
bk
file1.txt
file2.txt
fiel3.txt
*DIM,name,STRING
*DO,i,1,10
name=file'i'
*ENDDO
bk
