Printing PDF, once again
I have the workstations setup to print to a PDFCreator printer. We are using NX4. When I plot and print a drawing on my computer it works just fine. On the computer next to mine it prints two PDF files instead of one. Its the same file just twice. And the timestamp on each file is two to four second off. So its like UG is sending the plot command twice. I have checked everything in printer administration, and its linked to all the computers here, so they all use the same setting. The printer profile on each computer is the same. What else can I check to see why UG wants to plot twice. It does not do this when plotting to an HPGL or when plotting to a regular printer.
Rick
Rick
RE: Printing PDF, once again
