How can I run 2 Mechanisms at once?
Hello all,
Kinematics question: I have 2 Mechanism's set up in a CATProduct. I can run each separately, but how can I set if up to run both at once.
Basically I have 2 parts that follow the same path for a cetain distance, then divide into separate paths at a certain point of interference.
Any help would be great!
Thanks!!!
Thanks!!!
RE: How can I run 2 Mechanisms at once?
Actually I just figured it out and my boss is quite impressed.
If 2 points move along different curves, the same distance and set to take the same time - shouldn't they move at the same speed?
