Need 30" bellows
Need 30" bellows
Need 30" bellows
I'm in need of a 30" inside diameter x 20" long bellows to be used for sealing (not a perfect seal).  Temp rating must be 250F.  Anybody have any ideas?  Thanks.
-Plasmech
Mechanical Engineer, Plastics Industry
RE: Need 30" bellows
AFJ in Australia have supplied joints like this in the past.
http://www.afj.com.au/
Mark Hutton
Made a trip to the plant today while there checked on some non-metallic expansion joints in use.
The ones that were in use were the Teflon lined type but was told that they make an unlined one tha will take your temperature.
http://www.mercer-rubber.com/mercer/html/mercer/f120.htm
