Voltage drop calculation at starting
The first motor in operation draws big inrush current when generator is started and is on the line to switchboard. The inrush current of second motor will be lower than. In order to calculate voltage drop of second motor, what aspects are to be considered and how the voltage drop can be calculated.
RE: Voltage drop calculation at starting
Why do you think that the second motor will have a lower inrush? It may have, but we need to know why before going any further.
Note that if the inrush is less, it will probably last longer.
Bill
"Why not the best?"
Jimmy Carter
Keith Cress
I'd like to calculate voltage drop of second motor at starting.
Can you send the attachment as jpg or pdf or word or excel since dwg[autocad] is very difficult to read,do you?
Best Regards
I understood from your one line diag. that you have a Switchgear with 2 permanent coupled bus bar sections. From that Switchgear by means of 4 feeders 2 remote Panels are supplied.
AFT panel 2 feeders of 3*3*95 sqr.mm each of them supplying one half panel [3 motors]
FWD Panel also subdivided in 2 halves supplied by means of 3*3*120 sqr.mm.
Also I guess that each motor is provided with a star-delta switch for start.
In my opinion if the rated voltage of motors is 400 V [and 50 HZ frequency] according to permitted voltage drop [according to IEC 34-12] all motor M1 up to M10 are 75 kw rated and W1 and W2 are 110 rated.
Let say the switchgear is supplied from 2 transformer [1000 KVA, 420 V ,uk%=6+7.5%maximum error] then, when the M5-M10 will start the voltage on the AFT Panel [all other motors are already in operation] will drop to 385 V [4% drop- maximum permitted is 5%]
When W1 or W2 will start then the voltage on FWD Panel will drop to 358 V [11% >5% permitted.
If no motor is in operation on FWD Panel when W1 start then the voltage will drop only to
373 V [6.5% also >5% but still tolerable]
If you double the feeder that means 6*3*120 you may achieve 6% drop when w1 starts and M motors are in full operation.
My opinion!
See attachment
Best Regards
The maximum drop voltage permitted by IEC34-12 for a
limited time operation[if frequency is not less than 95%]may be 10% indeed[Zone B].
Also for M1-M5 starting the voltage drop is 6.25%[the voltage on FWD Panel drops up to 375 volts when all other motor is in operation]
