Introducing imperfection
Currently i am running a load-displacement analysis for buckling of cylindrical shells. The first step is introducing imperfection on a perfect cylinder and requires combinations of eigenmodes from linear eigenvalue analysis in order to find the critical loads.
My problem is I do not know how to combine several eigenmodes and write them in input file.I only know how to specify one eigenmode at a time.Below is the expression from the input file.
*IMPERFECTION, FILE=bucklecylshell_s4r5_n1, STEP=1
 1,0.0025
p/s: 1 is the eigenmode and 0.0025 is the degree of imperfections
thanx
RE: Introducing imperfection
It's in the keyword manual - you can specify as many modes as you need, i.e;
1,0.0025
2,0.001
3,0.002
Martin Stokes CEng MIMechE
great! thanx a lot...
i have tried specifying different combinations of eigenmodes from using a unique mode to combination of all eigenmodes but still i got a value of LPF(Load propotionality factor) higher that 1.
That means the critical load afer introducing the imperfection is higher than perfect cylinder which is theoretically wrong.
Hope somebody would help detect any errors in my commands below. Much appreciated it...
*HEADING
 RIKS ANALYSIS OF CYLINDER BUCKLING
 (100% thickness,*IMPERFECTION)
*NODE
 10,  100.,0.,0.
 14,  92.39,0.,38.27
 410, 100.,400.,0.
 414, 92.39,400.,38.27
*NGEN,LINE=C,NSET=LOADB
 10,14,1, ,0.,0.,0.
*NGEN,LINE=C,NSET=BND3
 410,414,1, ,0.,400.,0.
*IMPERFECTION, FILE=bucklecylshell_s4r5_n4, STEP=1
 1,0.25
 2,0.25
 3,0.25
 4,0.25
 5,0.25
 6,0.25
 7,0.25
 8,0.25
 9,0.25
 10,0.25
 11,0.25
 12,0.25
 13,0.25
 14,0.25
 15,0.25
 16,0.25
 17,0.25
 18,0.25
 19,0.25
 20,0.25
*NGEN,NSET=BND1
 10,410,10
*NGEN,NSET=REST
 11,411,10
 12,412,10
 13,413,10
*NGEN,NSET=BND2
  14,414,10
*NSET,NSET=ALL
 BND1,BND2,BND3,REST
*NSET,NSET=LDB1
 10,14
*NSET,NSET=LDB2
 11,12,13
*NSET,NSET=LDBFIL
 LDB1,LDB2
*TRANSFORM,TYPE=C,NSET=ALL
 0.,0.,0., 0.,1.,0.
*BOUNDARY
 BND1,YSYMM
 BND2,YSYMM
 BND3,ZSYMM
 LOADB,1,2
 LOADB,4
 LOADB,6
*ELEMENT,TYPE=S4R5
 1, 10,20,21,11
*ELGEN,ELSET=EALL
 1, 4,1,2, 40,10,8
*SHELL SECTION,ELSET=EALL,MATERIAL=MAT
 .25,
*MATERIAL,NAME=MAT
*ELASTIC
 30.E6,.3
*RESTART,WRITE
*STEP,NLGEOM,INC=60
*STATIC,RIKS
 .1,1.,,,,14,3,.6
*CLOAD
 LDB1,3, 49969.31158
 LDB2,3, 99938.62316
*EL PRINT, FREQUENCY=99
 S,E,
*EL FILE,FREQUENCY=99
 S,E,
*NODE PRINT,NSET=LDBFIL,FREQUENCY=2,GLOBAL=NO
 U,
 CF,
 RF,
*NODE FILE,FREQUENCY=1,NSET=LDBFIL,GLOBAL=NO
 U,CF,RF
*MONITOR,NODE=14,DOF=3
*END STEP
My first question would be whether you need to use all 20 eigenmodes to perturb the base structure?  If I use a *IMPERFECTION, I rarely use more than the first 2 logical eigenmodes.
My general workflow would be to;
1) Perform *BUCKLE analysis to get eigenmodes.
2) Run the *STATIC or *STATIC, RIKS analysis with no *IMPERFECTION.  Extract and plot the load-deflection response.
3) Run 2) again, but with varying amounts of imperfection, say 10%, 20%, 30% ..etc, and plot the load-deflection responses for each run.  I would start by just using the primary (first) buckling mode for the imperfection.
I usually find that after a certain value of imperfection, the buckling load does not change by more than a few percent.  I then set this as the imperfection value.
Ok. How to find the bukling load?
Do you meant plotting load proportionality factor(LPF)-deflection graph and then multiply the highest value of LPF with the applied load? If it so, the LPF should always be smaller than 1 for it to be theoretically correct, is it?
Depends on how you've set the model up.  I tend to apply a load that is easy to factor, so if I'm doing a buckling pressure analysis, I will apply a pressure load of 1MPa in the Riks step, so that, buckle pressure = LPF * 1 MPa.  In most cases, the LPF values will always be above 1 because I only apply a unit load of pressure.
Also, it depends on how you've predicted the buckling load.  Have you done it with a hand calculation?  Is it the load from the eigenvalue analysis?  In either case, the FEA may well over-predict and you'll get an LPF of >1.
Basically for eigenvalue analysis, I specified concentrated force of 1500 on 2 nodes and 3000 on other 2 nodes. That means the total forces applied are 9000. This is what been done in the ABAQUS Benchmark documentation input file and I tried to imitate them in my model.
I then multiply the total force with the minimum eigenvalue to get the lowest buckling load
So I use the same load for the riks analysis. Or should I use higher load instead?
thanx
There isn't anything 'wrong' with the loads that you have applied.  I don't believe that you need to use 20 modes in the *IMPERFECTION to trigger the buckling, that's all.  I looked at the ABAQUS benchmark, and they only use the first mode to trigger the buckling.
The load that you apply in a Riks step is a bit academic anyway, as you have to multiply the load by the LPF to get the total load.
okay, one more thing...from what i understand the LPF is the ratio of load/critical load. Does multiplying the LPF with the critical load obtained from eigenvalue analysis will give the actual critical load?
LPF = Load Proportionality Factor.
No, LPF is not a ratio of anything - the LPF is part of the output from the Riks analysis, as the load magnitude is treated as an unknown.  The LPF is printed to the .sta file and is used to determine the actual load on the structure;
Actual Load = LPF * Applied load
Section 6.2.4 "Unstable collapse and postbuckling analysis" in the v6.5 docs covers the principle behind the Riks analysis quite well.
