corrosion for steel piles
can anyone tell me how to handle the corrosion issue for steel piles? thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: corrosion for steel piles
1) contract out cathodic protection scope to third party. Depending on the soil conditions, water level, salinity,grounding; they will propose sacrificial anodes or hook up to an above ground active corrosion protection system.
2) Depending where you are, add 3 mm (1/8") corrosion allowance (in my case, Northern Alberta). We ground the pilecap reinforcement to one of the pile in the group.
Robert Mote
www.motagg.com
how long does it take for 1/8"? why do you ground the reinf to one of the piles.
http://www.slideruleera.net/Steel-Piling.html
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
![[r2d2] r2d2](https://www.tipmaster.com/images/r2d2.gif)
www.VacuumTubeEra.net
