Recloser Failure
Recloser Failure
Below is a picture from above of a failed medium-voltage solid-dielectric recloser with vacuum interrupters from an unnamed manufacturer. This recloser is designed with the control enclosure on top of the actual medium-voltage terminating components. The recloser was issued an open command immediately prior to failure and it appears the unit failed catastrophically during the actual attempt to open. Moisture within the top control enclosure was evident prior to this failure. I am curious as to the following:
- Is it feasible that moisture in the top control enclosure could have "seeped" downward along the drive assembly and into the actual medium voltage components (i.e. solid dielectric insulation and vacuum interrupter)?
RE: Recloser Failure
Possible loss of vacuum event?
