Distillation Rupture Disk
I am trying to size a rupture disk for a distillation tower. I am having difficulty finding information on how to do this. I am hoping someone here has had some experience with this type of application and can direct me to a good source or can provide me with the proper equations to do so.
Tony
Tony
RE: Distillation Rupture Disk
There is a pressure relief valve on the upstream piping as well.
There is a concern about possible side reactions within the vessel.
Perhaps note some additional considerations for the design:
A rupture disc will normaly need larger distance between operating pressure and set pressure than PSVs. Careful of design data for the vessel and disc compared to commercial available charachteristics for different types of rupture discs and disc materials especially at lower set pressures (Range 1-2 bar G), and different disc sizes.
Vacuum (underpressure) protection (by emtying and rapid cooling by water) is very often overseen. A vessel is normally weaker for underpressure than overpressure.
Rupture or leak detection recommended.
