Fatigue Analysis in Cyclic Service
For ASME Div. I vessels, what are the most common methods used for fatigue analysis in cyclic service?
Does the Code specify anywhere a preferded analysis method?
Thank you
Thank you
RE: Fatigue Analysis in Cyclic Service
In the cases that I was familiar with we used the old Division 2 to do the fatigue analysis, called for a few special weld details meeting the Div 2 radii and also required that small nozzles be calculated and did not per UG-36(c)(3)(a) to be applied.
EJL
Review API-ASME FFS-1
Also, I have been told that fatigue analysis is more an art than a science. Does this make sense?
As I understand the fatigue rules in the old Div 2 may have not been conservative in some cases. Fatigue life can be affected by the small details, the type of corrosion being one of them. I have not applied the two methods for calculating fatigue life provided in the new Div 2 but I believe that it will give different results.
Cyclic service requires a thorough understanding of the entire pressure excursions of the vessels, including the expected hydrostatic tests throughout the lifetime of the vessel.
I hope that I am being helpful.
EJL
As for the controling part...depends on the vessel type and the loading (thermal cycles, pressure cycles, etc). Most of the assessments that I have done have been on vessels with significant hot to cold cycling atthe cold to hot wall transitions (nozzles). Other than nozzles, highly constrained internal attachments may cause problems.
Anyway, hope that adds to the discussion.
jrjones
Sure seems to agree with one of my colleagues who described the process as "more art than science".
