How to import/build welded steel plates into STAAD.Pro
Dear STAAD.Pro experts!
I wonder if you could helpe me on defining of a complex cross section.
I'm trying to model a steel structure that is built up with welded steel plates as shown in the attached file.
I've tried "Section Wizard", but it didn't work!
I wonder if it's possible to find prismatic properties such Ax, Ix, Iy and Iz in AutoCAD then define a cross section in STAAD.Pro as prismatic sections with the corresponding Ax, Ix, Iy and Iz?
Please advise
Best regards
Bill
Please advise
Best regards
Bill
RE: How to import/build welded steel plates into STAAD.Pro
