Dual Dimension units
Is it possible to display the units of a dual dimension, ie showing it as [3.00mm] instead of [3.00]
RE: Dual Dimension units
GO to the options dialog, "document properties", "Detailing".  Under the top level, "Detailing", select the checkbox for "Show units for dual display"
Are u running 2008 as I am using 2007 and can't see the check box sad
