welding engine
welding engine
welding engine
ok i need help on welding my yamaha warrior engine. Im sure its aluminum. is this hard? if it is why is it hard? if i take to someone how much will it cost? please help
RE: welding engine
Let us not try to re-invent the wheel here, just take it to a certified welding shop capable of welding aluminum.  You will save youself a lot of time and money in the long run.
Rod
RE: welding engine
he is right.
but if you insist on doing it yourself I would suggest cold welding it. (depending on where the crack is)
but I must restate my agreement with evelrod
