Low Temperature Ratings for Metals
I'm looking for reference information regarding low temperature ratings for metals specifically 304,316,321, and 347 stainless steels.
RE: Low Temperature Ratings for Metals
In the case of API-650 tank construction, 304 and 316 may be used at any ambient temperature.  For pressure vessels, I think ASME VIII states that 304 and 316 may be used down to about -240F.  API-620 permits the use of SS for cryogenic temperatures, such as for LNG tanks.
Joe Tank
ASME BPV code gives temperature ratings for those materials.  I can't remember for sure, but I don't think you need any kind of impact testing down to at least -320, possibly lower.
Please find the following limitation in ASME.
Temperature Limitation (deg.F) of Materials in ASME Code, up to add. 2004
Materials        Sec VIII-1        Sec VIII-2        B 31.3
304 SS            -320~1500    -320~800    -425~1500
316 SS            -320~1500    -320~800    -425~ 800
321 SS            -320~1500    -320~800    -325~1500
347 SS            -320~1500    -320~800    -425~1500
