Reuse Library Problems
I am having trouble bringing up the directories in the Reuse Library menu.
The directories that I have specified are there along with others that are not on
the system (???). When I select the required directory I get a "A deleted or invalid
class ID was used" If i try to right click the directory to remove the known directories
that do not exist the message repeats its self. How do I remove the directories
at this point a get back to a blank slate. I am hoping removing the bad entries
will solve this problem. I am using the latest vs of nx in native mode.
Chris
Chris
RE: Reuse Library Problems
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
I have the path correct and it does show up. I also seem to have two other paths shown that do not even exist. I can not delete them (right mouse click) and I can not find a way to eliminate the incorrect dir that are there. ???
Chris
